when I run a application as admin, I get no Listary toolbar
I have make a GIF animation
What should I do to get every time the toolbar?
Thanks
Andy
Thanks
Andy
When you run an application as admin, it becomes “untouchable” for Listary because Listary only has normal privilege. You can also run Listary as admin, but it will become buggy and this is highly not recommended.
When I start Listary with admin rights, I can’t switch to network drives
Is it possible to fix that?
Andy
Unfortunately, no. As I mentioned above, Listary will become buggy when you run it as admin.
I may have just found a solution. I’ll test it soon.
sounds good
