Allow running shell commands OR passing arguments and switches
Like the behavior of run window and start menu, so that the following are possible:
ping google.com
winword /a (to start without addins)
cmd /k ipconfig
cmd /k ping google.com
pip install numpy
It’s frustrating to have to create a custom command to do this for every possibility, instead of just being able to do it on-the-fly
here is Wox’s implementation: https://github.com/Wox-launcher/Wox/wiki/Default-Plugins.-Command-line
Doesn’t the {query} placeholder work for you?
That’s for web searches. You can create a custom command with arguments, but it is not possible to execute a command on-the-fly. See the link for an example of what I’d like to accomplish with Listary.
This is very easy with a custom command:
Thanks!!
